stock 4.8 turbo build
Im in the middle of a frame off restoration on my 64 Bel Air and will be putting a 4.8ls with less 40k miles in her. I want to do a single turbo setup and will be running a th400 trans. I have followed a few similar build threads but could use some guidance. My goal is 550rwhp. I need some help deciding which turbo, piping, stall, wire harness, intercooler, and mounts to use. This will be driven on a weekly basis and falls in the "pro-touring" style build. I will be using a stand alone harness and the motor has electronic throttle that came stock.
