Turbonetics, Garret, or S400
Old 04-20-2014, 10:14 AM
LS1Silverado05's Avatar
Default Turbonetics, Garret, or S400
Working up a build on a L76 6.0... I need some opinions on Turbo selection. It will be a single front mounted turbo. Probably located in the stock air box location (Pontiac G8).
2.5" Hot side, T6 Flange, 44mm WG... Trying to keep a budget but select a turbo that will spool reasonably well and be capable of decent power levels (800+). Any thoughts or real world experience on the ones below?
S400SX75 (1.32ar, 96mm, T6)
Garret GT76 (1.23, 94mm, T6)
Turbonetics T76
Old 04-20-2014, 07:23 PM
Turbo5.0's Avatar
Do the S400!
Old 04-20-2014, 08:12 PM
Restricted User
JoeNova's Avatar
The 400 is quite a bit bigger than the other two. The turbonetics being the smallest. A lot of people run into a space issue with the BW turbos
Old 04-20-2014, 08:20 PM
soccerdave's Avatar
would the turbonetics be better for a twin setup on the 6.0L?
Old 04-20-2014, 10:09 PM
Forcefed86's Avatar
Any of those turbos should make 800+HP on a 6.0. BW stuff is great for the price if it fits... It was a chore stuffing an s400 into my engine bay. Either of the two smaller turbos mentioned would have made install much easier.
Here is a good comparison....
Quick Reply: Turbonetics, Garret, or S400
