DTC P1336 (Crank positon relearn)
Old 05-16-2004, 12:45 AM
HumpinSS's Avatar
Default DTC P1336 (Crank positon relearn)
How do I get rid of it. Just swapped pPCM because of a bad Edit flash an now I have this DTC being set. I tried a CPK relearn in EFILive but that didnt seem to work. Are there any other things that I need to try on a 2000 F-Body.
TIA
Old 05-16-2004, 08:31 AM
Bink's Avatar
Hey! Have you tried using the latest/updated version of EFILive? I think there were some issues with crank relearn and earlier V6 releases.
joel
Old 05-16-2004, 08:45 AM
Bink's Avatar
HumpinSS - Here's the EFILive info/Thread I was thinking of http://www.efilive.com/forum/viewtopic.php?t=346 .
Blacky recommends V6.2 or later for relearn. Interesting thread.
Hope this helps!
joel
Old 05-16-2004, 09:30 AM
HumpinSS's Avatar
I am running the latest version but i dont think i am doing the relearn right. After reading that thread I will try a little later. BTW I got the cam installed and the thing lopes and makes power like no other. I will have a sound clip later on today sometime.
Old 05-16-2004, 11:48 AM
Moderator
jimmyblue's Avatar
Other faults will inhibit the crank relearn, I had
some kind of fuel tank pressure sender problem
(according to the dealer, after I also could not
get the relearn to go) which, though it set no
code, they replaced and managed to force the
relearn with the Tech2.
Old 05-16-2004, 12:36 PM
Bink's Avatar
Can't wait to here it.
joel
