Losing coolant no signs of pushing???
I have a 93 mustang with 408 lq4 block and 317 heads with a valve job. Ls9 head gaskets. All arp bolts and studs. New 3 core radiator with 16 psi cap I believe that's what comes on mustangs. Trick flow steam tube kit on all 4 corners going to upper radiator hose. Turbo is s480r. Car has about 300 miles on it now. Car made 825 hp at 18 psi through unlocked 4l80e. On the dyno we never had any signs such as coolant smell or haze out of the exhaust. And I've never noticed any thing cruising around. However I keep having to add coolant.
Example is on dyno day it was running a little warm and I haven't checked it in weeks. It was like 6 inches low in the radiator. So topped it off, been driving a bit more and had to add to it 2 more times. About 3 inches low yesterday after driving 60 miles. And doing 2 pulls at 10 psi.
I've checked oil and spark plugs no signs of coolant. I'm thinking next maybe pull off my manifolds and see if I see any signs off coolant. Anyone have any thoughts?
Unless there is a leak in the system you dont know about, its drinking coolant. If it wouldnt have been for my old *** cap, i wouldnt have known mine was until the coolant light came on. Turns out i was lifting the driver side head. Never had a problem on the dyno but as soon as i hit the highway it would lift.
Been dealing with this same crap. I did spot a tiny area by the radiator drain, but it does not seem it would leak out that much from there. Not even a visible puddle. Thinking of pulling manifolds on mine too but I would think with that much it would show as steam in the exhaust.
loosing coolant here as well. constantly having to add but I dont have any visible leaks. i lightly copper coated my ls9 headgaskets and torqued them down once the the spray was tacky...wondering if i should have installed the heads dry...smh...
UNDER PRESSURE MOD
There was a guy on here who put a gopro in his engine bay and found a huge leak when he hit a certain psi of boost. I think it was near his radiator overflow. Normal driving it didn't leak, but when he hit full boost it was like a gusher.
So you could always toss a camera in there and see if you see anything.
Is the level in the overflow increasing. I was damn near about to pull my 5.3 out of my s10 because i kept losing coolant and i forsure thought it was something serious. I had replaced my rrservoir with a smaller one from summit and it would push while running. Got rid of that ****** and went back to my stock overflow and i havent had a problem. Collant has stayed the same level in the radiator and overflow for 2 weeks now. Id do a leakdown test personally if the cap isnt bad
8 Second Truck Club
I bet that can is the issue. How does it vent? Also are you absolutely sure that you had it full to begin with. When we first got mine running I filled it and same ****. Finally realized that it just hadn't been completely full yet. If I was to bet pull that over flow tank off and just let the hose hang (no overflow) drive around a few days and see if the problem still exists. I bet it won't
Dude thats the same reservoir i had. Take that bullshit of your car lol. Something about those reservoirs are flawed because i havent had a problem since i removed it. For one the grommett on top always had air escaping out of it which prevented vacuum from building to pull the coolant back in.
