P1SC what pulley for 6-8#?
Old 04-23-2014, 09:53 AM
Fst_Byrd's Avatar
Default P1SC what pulley for 6-8#?
I have a 99 Trans am and im in process of ((yes still haha)) getting the procharger setup put together.
Im wondering what size pulley Im going to need for my desired boost level.
Also what size belt I will need dfor that pulley.
The Engine is a stock internal LS1,stock ls1 intake, stock cam.
only upgrades it has is a ported throttle body and Edelbrock long tubes...stepped with a 3.5 collector. That goes into 2.5 true duals all the way to the back with hi flow cats, x pipe and 2 magnaflow muffs
Im only looking to start around 6-8#'s from the P1sc, twin 3.5 coolers, proflow bypass and meth injection..OH yeah also will be an 8rib with the base 7.65 crank pulley.
Can anyone help me figure this out? I have a few pulleys but not sure which one I'll need to use, or buy new one.
Old 04-24-2014, 09:50 AM
Fst_Byrd's Avatar
Nobody has ideas of which pulley is needed for this much boost? I have searched like crazy as well as called ATI. The guy from ATI didn't seem to know his head from his *** and was no help at all.
Old 04-24-2014, 10:36 AM
Blackpanther99's Avatar
Between a 3.7" to 3.85" should get you there.
Call bob at brutespeed, he will get you setup.
Quick Reply: P1SC what pulley for 6-8#?
