problem putting belt tensioner off!
Old 04-23-2014, 01:52 PM
ikaros23's Avatar
Default problem putting belt tensioner off!
I guess this is shot cause I cant find a way to put it back on as it rubs the ac compresor pulley completely! it looks like the pulley is on the high side. right or wrong?
Attached Thumbnails problem putting belt tensioner off!-2014-04-23-14.46.08.jpg
Old 04-23-2014, 02:20 PM
ikaros23's Avatar
bump!
Old 04-23-2014, 02:58 PM
DUDCOUPE's Avatar
It does look a tad high, did you try installing it and putting the belt on?
Old 04-23-2014, 03:07 PM
Mystery Bird's Avatar
It looks bigger than mine. You're not trying to put it on upside down are you?
Old 04-23-2014, 03:08 PM
ikaros23's Avatar
yes I did but it wouldnt go in. but right after I took the belt off I noticed the tensioner pulley to be to close to the one from the ac. if I spin one by hand the other one would spin too cause its sits right next to it.
shbox's Avatar
IDK, does that pulley look a little big? Optical illusion?
http://shbox.com/1/accy_brkt.jpg
Old 04-23-2014, 03:12 PM
ikaros23's Avatar
found a pic online , it seems mine just went bad. oh boy so much for 200 miles lol
Quick Reply: problem putting belt tensioner off!
