russel pro flex hoses or not
Old 04-25-2014, 10:30 AM
Boosted Firehawk's Avatar
Default russel pro flex hoses or not
For fuel lines to the rail and regulator???
Old 04-25-2014, 09:19 PM
Project GatTagO's Avatar
Received 1,386 Likes on 875 Posts
I wouldn't use anything other than teflon lined hose.
Andrew
Old 04-26-2014, 02:40 PM
Sarg's Avatar
Why is that?
Old 04-26-2014, 06:55 PM
Firehawk441's Avatar
Originally Posted by Sarg
Why is that?
Fuel odors.
Old 04-26-2014, 07:43 PM
Bimmerdude's Avatar
All rubber lines are porous to some extent and fuel is a pretty small vapor so it gets through easily.
Oil will even eventually weep a bit.
The teflon lines acts more like a hardline and seals up the porosity.
Old 04-26-2014, 09:51 PM
Sarg's Avatar
With the synthetic rubber lines I have, I have not experienced any odors. Push on fittings as well.
Old 04-27-2014, 05:34 PM
Why is that?
I used to work for a major aftermarket company. One time I went back to the engineering department and saw that they had dozens of little glass jars sitting there with small sections of hose inside liquid. I asked what that was all about and was told that they were testing the effects of various fuels on different hose (their own and their competitors). After seeing those jars and what gasoline eventually does to that hose, I will never run it on anything besides maybe a race car that gets regular inspections. The short of it is that in not much time all hose was starting to deteriorate pretty badly. Race gas was actually not as toxic as different street blends, mostly because of the ethanol content. That's why I prefer the teflon hose. The odor is another area where the teflon hose is superior.
Andrew
Old 04-27-2014, 08:20 PM
Sarg's Avatar
I guess their hose was crap compaared to the OEM hose that Subaru uses. I ran E85 for 3 years on factory Subaru hose and after tear down it all looked better than new. Valves and pistons looked great too...
Old 04-28-2014, 07:11 AM
stevieturbo's Avatar
Andrew
Unless the fuel lines are inside the cabin...doesnt matter at all.
If they're in the engine compartment, any good quality hose will be fine, teflon is certainly not needed.
Old 04-28-2014, 07:13 AM
Andrew
Not a valid test. Most hose is not designed to be submersed in fluid. So you would expect them all the suffer badly if you do. Only the inner lining is designed to be in contact with said fluids.
Again, all boils down to correct and appropriate use of any hoses.
Old 04-28-2014, 09:26 AM
2muchboostNY's Avatar
^Stevie hit it right on the head. Many hoses are compatible for contact with fuel and not compatible for submerging the hose for prolonged periods of time in fuel. Teflon is great as are other PTFE blended polymers (Teflon-synthetic blend) but typically much more expensive. For E85, the higher the PTFE blend content, the greater "compatibility" with E85 due to the ethanol content just in case it was a question. Not to say that other synthetic blends which do not note PTFE as a material has not worked for some.
Old 04-28-2014, 12:30 PM
So stevie can I use this hose or not? Street car at that.
Old 04-28-2014, 12:31 PM
If not I will just buy fragola ptfe pre made lines and call it the day.
I just have bulk of this in stock right now.
Old 04-28-2014, 01:00 PM
soccerdave's Avatar
use the PTFE lines hands down e85 is messing everything up in older fuel systems
Old 04-28-2014, 06:03 PM
Ive already answered.
Unless the lines go inside the cabin, there is no specific requirement to use PTFE unless the type of fuel you are using demands it.
But in short, use as per manufacturers guidelines.
But as you dont mention overall routing, and dont mention the type of fuel, etc etc etc...I cant give any other answer
Old 04-28-2014, 11:08 PM
Steve sorry about that. With e85 and lines from the undercarriage to the fuel rails
Old 04-29-2014, 05:17 AM
firehawk 385's Avatar
Hard line or PTFE hose.
Old 04-29-2014, 12:27 PM
Ptfe it is then
Old 04-29-2014, 01:43 PM
If you want a trouble free system then PTFE it is for E85. My buddy worked on this research you can find in the link below.
http://iqlearningsystems.com/ethanol...patibility.pdf
If I may also suggest, use a Stainless Steel filter for E85. Most of the guys up in the NE with E85 coming out of a particular shop used 100 micron and a secondary <40 micron filter. E85 is not as strictly regulated regarding contaminants and such so the E85 blends we have seen in NJ, NY, and CT can be filthy at times. Not to say some locals we know havent gotten away with using other types of filters but some have shown deterioration of non-SS filters. The combo has not resulted in any issues to date. Some of the guys have been running E85 for 3-4 years without a hiccup. Again, this is what I have personally seen regarding many imports and E85.
Old 04-29-2014, 07:32 PM
Bimmerdude's Avatar
On my car I'm running stainless hardline until I'm in the engine bay, PTFE from tank to hardline and hardline to engine - No fuel limitations, no odor and looks nice and tidy
Quick Reply: russel pro flex hoses or not
