plasti dip on wheels users inside...
Old 04-25-2014, 05:00 PM
Moderator
thechef's Avatar
Default plasti dip on wheels users inside...
i am looking to paint my wheels on my G8 GT and see that alot of people use Plasti Dip.
I want to know if the Plastic Dip will stay on and hold up to bringing the car through the car wash???
Please share your experiences
Old 04-25-2014, 05:56 PM
LT4vert's Avatar
Not sure about a car wash. I can say a friend had his entire car plastidipped and it made it through the entire winter un-marred. My wheels have been done for a couple months now and still look perfect after a few washes. I uses a boars hair brush to scrub them.
Old 04-25-2014, 06:57 PM
whiteheartbeat's Avatar
I've done a few brushless car washes with my truck that has plasti dipped wheels and never had an issue. Wheels have been done two years already and still look good!
Old 04-29-2014, 11:31 AM
Brutal Boba Fett's Avatar
TechCam97 and I did my Speedline about a year ago and they looked pretty good. Only took them off because I got new wheels. I took them through several car washes, even some that specifically spray the wheels and rocker panels and never had an issue. Even if they do get hit by a rock or scuffed when you pull a wheel off or put it back on it can be repaired with a couple of fresh coats over the old stuff (once you have cleaned it).
Old 05-04-2014, 03:39 PM
WCT13's Avatar
Just finished painting my wheels with it.
Only took 2 cans, used some degreaser to clean the wheels before hand. Not to bad IMO.
Old 05-04-2014, 03:44 PM
formula218's Avatar
i've used it on 3 or 4 of my personal sets of wheels and have never had any get damaged from washing them. i usually just scrub them with that brush on the wall at the quarter spray wash.
Old 05-04-2014, 06:16 PM
silent_soul's Avatar
mine are painted and have been painted for over a year. I have taken my car through every kind of car wash and even pressure washed the rims. PLasti still stays just fine....im actually kinda worried when I go to remove it if Ill have issues lol.
Old 05-04-2014, 06:23 PM
WCT13's Avatar
I am going to paint a piece of pipe and keep it hidden until I decide to take the plasti off and see how hard its going to be to take off. I wonder if direct sunlight at 90-100 degrees will bake it on their?
Old 05-04-2014, 08:26 PM
formula218's Avatar
i had to remove some once and the hardest part is getting a hole started so you can start, once you do that you can take it off in large pieces for the most part. my wheels have plastic center caps and those were worse than the wheels but still not bad.
here are the wheels i've got dipped now. i've also had C5Z wheels like above, 17x11 ZR1s (in sig), and Torque Thrust IIs that were all dipped black and have never had an issue with any of them.
Attached Thumbnails plasti dip on wheels users inside...-10172631_10151945537766082_6934876216411528295_n.jpg   plasti dip on wheels users inside...-img_9342.jpg
Old 05-05-2014, 08:20 AM
I am about to sell my Speedlines and i am trying to get them all cleaned up. They have been dipped almost a year and it came off pretty well. The only real issues was where I didn't put it on thick enough, but with a little elbow grease and some Goo Gone everything is coming off quiet nicely...
Old 05-05-2014, 04:16 PM
SSelDiabloBlanco's Avatar
Mine have been dipped for a year now. No problems so far!
Old 05-05-2014, 06:51 PM
Alot of people say for thin areas use a microfiber cloth and rub it off
Old 05-05-2014, 07:27 PM
TechCam97's Avatar
Yep, that's what we did. We just used some Goo-Gone to help get it loose and get ride of the residue.
Quick Reply: plasti dip on wheels users inside...
