Oil pan gasket problem
So I replaced my pan gasket and I didnt even put oil in it and I see some oil seepage at the rear of the pan gasket. I cleaned the surfaces thoroughly and its leaking from the same spot.
Gonna drop the pan/gasket and reclean it all then do it again. If it still seeps, whats my problem? Pan?
If it's leaking and you didn't start it, keep looking. See if you find oil at the back of the block just under the intake or at the rear of the valve covers.
Al 02, 95, 86, 73 Z28's
confirm the leak is FROM the pan and not somewhere else
rear intake
RMS
RMS adapter plate
putting dye in oil and looking for leaks with blacklight if you can't see the leak source helps
when I put pan gaskets on I run RTV corner to corner front & back
rear intake
RMS
RMS adapter plate
What gasket and pan are you using? When I installed my Canton pan on my new engine I used the Canton gasket they recommended and had a bunch of leaks. I replaced the gasket with a Felpro unit (the blue one you can get from any NAPA store) and did the RTV as ****** described and haven't had drop of oil on my garage floor ever since.
