408 F1R build.......
Chris hit me up shortly after buying the F1R kit off my white car to have itinstalled. Things escalated quickly. ....
my old setup he purchased.
The parts list for his build:
Procharger F1R w/ kill pulley
Custom ic piping w/ Tial bov
LQ9 408 10.5:1
LS9 hg
Hand ported AFR 245s w/ 1.8 rockers
Morel link bars
BTR 243/263 .627 .632 115 +6 blower cam
1200hp fuel system w/twin 340s -10 feed -8 return
AmericanRacing 2" headers with 3.5" collectors
3.5" duals into oval side exit boyce boom tubes
9"
Fast 102/102
Alkycontrol twin nozzle meth kit.
BMR suspension....
Currently the car is a 6 speed with a Mcleod rst and a stock trans but a glide will take its place very soon. .
On to the pics. ...
LQ9 408 10.5:1
LS9 hg
Morel link bars
9"
Fast 102/102
BMR suspension....
On to the pics. ...
I agree.... if we run into belt slip we will upgrade to the aster.... if the meth cant keep iat in check ill build a fmic.... however for what its worth I was running the standard ati 8 rib with an f1r at 16psi without any belt slip.... we will see what happens.... the goal is 1000whp and hurt some feeling at the track and street...
Got anymore pics of the exhaust set up? I always thought that would be a wicked looking set up with a big oval pipe slashed cut to the sides.
What pulley combo were you running before to get 16psi with the R? What size engine?
-Coleman
-Coleman
Looking forward to the pics and progress!
UNDER PRESSURE MOD
Aster's bracket really isn't that expensive. Look at the cost of a stock "J" bracket, add in the cost of a LS2 water pump, which is a good upgrade over a stock one, and you'll see it's about a $100 or so upgrade. I know, I did the math when I put my setup together. I pieced it toghether, and the cost of doing Aster's bracket vs. a stock bracket with an 8-rib upgrade and getting a water pump, it wasn't much difference.
BTLBABY.. im definitely not going to run a 4.85 on this setup. . I've got a 4.0 on it right now. .. but also have a 3.85 and a 4.25 ...
Alchamist is right. .. aster is really not that expensive at all.. im just curious to see if I can make this work before jumping on the aster/cbr bandwagon..
Yeah, I didn't figure you would be. Just pointing out the smaller engine is easier to make that boost number than the 408 will be. I really think y'all will be fighting slip to get any decent amount of boost. Guess time will tell! Keep us posted!
-Coleman
-Coleman
UNDER PRESSURE MOD
Aster needs to see what needs to happen to run a 12 rib setup like the 5th gen camaro guys have. That would be kickass for running the F1-R to F1-X. I'm guessing it would mean spacing out the blower from the block, and getting wider pullies for everything, but in theory it would work.
It would be awesome to be able to run a 12 rib, I just don't see it being able to happen with out modification of the radiator and/or lower radiator support.
Even with my SDCE set up spaced out a little over a 1/4", I have a hard time getting my inlet hat on with the radiator in the factory location. I bet the 12 rib is easily another 1/2-3/4" more spacing than the SDCE. Does anyone know what the actual difference in width is in the 8 to 12 rib?
