Fast 102 has confused me already
the more i research the more lost I feel. My setup is a Fast 102 for cathedral port heads. I am running LS1 style injectors, so logic says i need an ls2 rail? I found a L76, which everyone says is the same as the ls2 ls3 but now i see on all FASTS rails they dont list this?
I'm trying to figure out if I can use a factory rail for an ls2 with the fast 102 manifold and if the L76 rail is the same rail as the ls2 so I can use ls1 injectors in the ls2 rail with the fast 102
Oh, I know the LS2 rails work, but I can't say about the L76 rails, as I've never had a set. According to this post onCorvetteForum the LS2/3/76 rails are the same.
Thank you sir. See that's exactly what I mean. I read they are the same part number but then I've read that fast has a different part number and puts the L76 as ls3 rails and the same
But according to gm it's all the same part number.
