Category: Accessories
Price: $50
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): MO
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
Wiring your nitrous kit has NEVER been so easy or fast!! Simply connect your battery positive and negative to the board, connect you 12volt power from your throttle switch or manual nitrous button, connect you transbrake or clutch 12volt signal for nitrous safety so that your nitrous will not come on it your on your transbrake or have your clutch engaged, connect your 12volt purge signal from your purge button, then connect your nitrous and purge solenoids to the board and you done!!!
Board Features: On board 70 amp relay for nitrous solenoids, 35amp relay for the purge solenoid, indicator LED's for easy troubleshooting, built in transbrake safety relay to prevent nitrous activation while on the transbrake of clutch, and board uses heavy duty J-Case automotive fuses. J-case fuses not included.
Also makes wiring Nitrous Progressive Controllers simple too!! Check out the wiring diagram in the pics.
This costs $60.00 plus shipping and handling from Leash. I'm selling it for $50.00 plus shipping and handling. If using Pay-Pal, add in the 3% fee. Item is boxed up and ready to go.
