Two awesome laps at Road America and then engine carnage
The car was doing very well until the poor abused LS1 spun a rod bearing on piston 8 (@7:00 into the video). We bagged a 2:45 and a 2:41 lap, and then the rattling started...
Oh well. *sigh* this just pushes forward my 475 HP LS6 build, which is about 80% complete.
sorry for the washed out look of the track, the camera was self-adjusting for the dark car insterior.
Karl,
So sorry to hear the news. What was your oiling setup on that LS1? Are you on slicks? I am about to start tracking my LS1 and am going to go with the Improved Racing Baffle/Scraper, my stock '02 LS1 (think the the LS1 and LS6 pumps are the same that year) pump and will probably overfill 0.5-1qt but am wondering if I really need to think about an Accusump before hard use like what you put yours through...your car is AWESOME by the way!
I switched to the slowest car on the track, my good ol' Grand Prix GXP. Awesome in a straight line, but you really gotta plan ahead if you want to turn the thing. I think the TA averaged 90 through the carousel, and hit 140 at the ends of the big straights. The GP averaged 60 through the carousel and hit 115 if I pushed my luck.
Karl,
Thanks! The oiling system was stock 2001 base Corvette everything - batwing pan, stock pump, stock lifters... the whole deal. Engine 2.0 has a high volume Melling pump, and will have an accusump system added. We have a few weeks before the next track weekend, so I'm open to other suggestions.
I know the Accusump will certainly help, but I"ll admit to ignorance on the improved racing baffles. I'll definitely check those out. I've never experienced the oil starvation due to hard sideforce that people have had issues with. Seeing as this failure came at the end of the front stretch, I'm inclined to think this was more of a "normal" oil starvation cause. The engine spent a lot of time at high rpm.
I'm hoping the high volume pump makes a positive difference. I've noticed the the pressure in the now deceased ls1 had been around 30 at hot idle lately, which is lower than I recalled from last year (thinking maybe 35). I probably should inspected it more closely, but was concentrating more on the new engine and hoping this one would last until after the mfba Road America event.
I am doing the Improved Racing Baffle and the Crank Scraper on my build just for longevity/reliability purposes and will do the Accusump when I move up to sticky tires after a learning period on street tires.
http://www.improvedracing.com/baffle...ffle-p-30.html
http://www.improvedracing.com/oiling...rs-c-3_50.html
Yes the crank scraper will help get the oil back to the pan where it can be picked up again faster and is pretty cheap. That is too bad they don't make an oil pan baffle for your application but you can always check to see if someone else makes one?
