where to buy 3" wheel studs
Unless you pull your axles, I don't think you will beable to get them in there. I went to O'Reilly's and bought some for my car. The thread length was normal they just didn't have the little non threaded nipple on the end. I had to dremel the "nipple on the end of the stock ones to get them to come out. Then the new ones slid right in no problem. But I have TCS and ABS, so if that matters. Just thought I'd tell ya. Good luck.
Chris
Chris
If your car has ABS you can install the rear studs without pulling the axles. If it does not, pull the axles. The GM studs are long, but the last 1/2" is not threaded. I switched to the ARP's and prefer them.
