anyone running the bmr high clearance kmember?
Looking for people who have the bmr high clearance k.finally got the motor in the car after building my twin setup and every thing looks good both alignment dowls are in there respective holes but my motor seems to be sitting about 1 inch towards the passenger side, this normal? Wouldnt think so, im sitting here scratching my head wondering what and need some input.passanger shock tower clearance is far tighter than it should be imo and I have tons of room on the drivers side . something has to be off but nothing quite obvious
The one with the vertical motor stands? I put one in my car fitment seemed great. Havnt run the car yet but seems to be sitting centered in the bay (just went and double checked lol)
I'm running a truck mani on the drivers and a c6 on the passenger side and have plenty of clearance on both sides.
Yeah its the one with vertical stands.at first I didnt notice the motor sitting to the right.got measurments tonight from my friends ta and motor is definitely 1 inch over on the passenger side.really hoping its some thing stupid . fitment did seem great as well on mine.i am about to try and reposition everything here shortly and see
interesting, I'm building a TT set up for a friend, he has this K member and it is off set 3/4 inch to the passenger side also. I did V-banded truck mani's and had tons of room to run the 3" DP's on both sides. I figured it was normal, as GM did that in other cars. it really made it a pain in the *** to make the set up look balanced!
I bought mine from dkt. Car is running and driving with no issues. My motor is centered tho.
They make more than one version of "turbo" k-members.
One being discussed in here AKA "DKT version" https://www.bmrsuspension.com/?page=...160&superpro=0
The one I am guessing you are having issues with - https://www.bmrsuspension.com/?page=...260&superpro=0
I just got the kmember straight. I had to loosen all the mounting bolts and shock mount bolts. (wheels off the ground of course) I put a bottle jack on the frame rail and engine block. I pumped it up until the motor was a little to the driver side (since I had the factory rubber motor mounts in i knew they were going to have some give in them). I also removed the driver side rear kmember bolt and that was the ticket. I was then able to get it all straight. I had to carbide bit that bolt hole quite a bit to be able to put the bolt back in.
