3 BAR MAP LS6 intake
I bought the ZR1 3 BAR MAP (pn: 12592525) and just realized that the connector is different than the male connector on my LS1 harness (04 GTO). Is my only option here to buy the expensive Lingenfelter adapter harness?
I could drill and tap the hole and put a NPT fitting with a barb in it but I'd rather not. And I'd still have to do something about the electrical connectors being different types and not fitting. If I can find a plug and play 3 BAR I'd rather just return this one.
Yeah good point... figured it would be too good to be true. Thinking it over, I will probably just tap the rear MAP hole and put a fitting on it to to run this ZR1 MAP. I just hate to have to spend $30 on a harness adapter to make it work. The fitting I could care less about because I already have some quick fit fittings that will work.
Nothing wrong with the EFI source sensor... price doesnt always reflect quality... I mean cmon i sell the stock ZR1 map for 36 bucks.... by your reasoning its not any good either.....
I calculated them from the transfer function. I am not convinced that calculation gives the correct offset.
Anyway, I'm using mine anyway.
So if anyone has Dsteck's sensor and would care to share those numbers with me in private, I'd like a sanity check of my values. I used the same Freescale 3 bar sensor he uses.
Ron
