Balancer hub alignment position
Old 05-09-2014, 02:27 PM
mhslax6's Avatar
Default Balancer hub alignment position
I've read that #1 should be at TDC and then the hub arrow goes on at the top. If that is correct the cam pin should be @ the 9 o'clock position, correct? When I look at mine with the arrow up, the pin is at 3 o'clock. Is it OK? Is it because #6 is also at TDC?
Old 05-09-2014, 02:36 PM
shbox's Avatar
Yes, it is ok. The hub arrow is at the top at both 1 and 6 TDC.
Old 05-09-2014, 02:53 PM
mhslax6's Avatar
Thanks, appreciate it as always!
Quick Reply: Balancer hub alignment position
