HELP, Need expert advise!
Clutch experts please chime in. I just installed a new master cylinder in my c5z06 & now the pedal won't go down. It won't budge! The install was easy & went really smooth until I tried to pump the pedal to bleed it. I even unhooked it from the pedal to ensure the pedal wasn't the problem & it moves freely when not connected to the cylinder. The fluid levels are normal & the slave was replaced when the clutch was done. The only reason I replaced the master was it had a leaky seal. Any advise will be greatly appreciated. Thanks!
