Removing clutch pedal question (t56 to th400)
So I searched and nothing simple came up. Just wondering I've swapped from a t56 to a th400, to remove the clutch pedal do I need anything or is it something that I can just take off? From glancing it looks like it's attached with a through bolt to the brake pedal as well. Any help would be great.
just did it..pop off both springs, remove switches, take off the 13mm nut on the pivot shaft, slid that out, remove clutch pedal put shaft back in just don't over tighten nut..
