Nitto Drag Radials On Road Course
Originally Posted by gator's 99TA
if you want to be competitive, i wouldnt suggest it at all,. the sidewall is far to weak for the lateral pressures in cornering. but if you still do, go as high as possible. over 40 psi - and yea tire wear will eat you up at that pressure.
Be careful making assumptions, or taking them from those that have never tried.
Nitto drags are fine on a road course, especially the 17's. Several racers I have know have raced on them, and all of us liked them and were fast. I autocrossed on 16's DR's years ago and thought they were a little sluggish. I actually think my car is faster on a road course with Nitto DR's than with Kumho Victoracers in the same size. I run 315/35/17's on 17x11's at all four corners. They last a lot longer than Victoracers. The other thing I love about them on a road course is the fact that they make noise. It is much easier to drive them at the limit.
Photo 1
Photo 2
Video on drag radials
EDIT: I have also owned the 555RII, their road race tire. Actually I still do, and am on my third set of four. They are my street tires, also a nice tire, and basically only offered in a 275/40/17 (and very expensive 18's). They are a great tire, but not very different at all from the 555R.
Photo 1
Photo 2
Photo 1
Photo 2
Photo 1
Photo 2
Nice video.
Beautiful car BTW. I love silver!
One last thing. I would not suggest running stickies out back and street tires up front on a road course. Our cars tend to push (understeer) stock, and mismatching tires can exagerate this effect. You probably know this, but get a good set of front pads (I like Carbotech Panthers) and good brake fluid (Motul 5.1 or Ford HD), and have the following alignment done before RR:
Camber: max negative, or -2º (about -.5º is all you will probably get)
Caster: max positive, or +5º (lucky to get +4 stock)
Toe: 0. A little toe out will handle better on the track, but is a handful on the street. I run 1/8" toe out and love it.
