hanging rpm on dyno
Old 05-11-2014, 11:33 PM
ta02zx10r's Avatar
Default hanging rpm on dyno
I finally got the car on the dyno last month and for the most part went fairly well considering it was basically a shake down for a long drawn out build.
I am trying to track down some specifics and I'll do my best to get details from the tuner. Car is running strong minus the rpm "brick wall" on the dyno at 5800 rpms.
Build is as follows:
lme 408
trickflow 6 bolt 235's w/springs spec'd for .700 lift don't have open and closed seat pressures
235/231 621/609 115
twin tc 72's
dual exhaust w/cutouts on the downpipes
jakes perf 4l80e w/ 3200 billet stall single 10.5" lockup
stock ignition w/ tr8's gapped to .028
91 octane (I have methanol injection but it wasn't used on the dyno runs that day)
Car made 746hp and 726ftlbs on 10lbs pulling to 5800 rpm (I'll have to double check dyno numbers on the sheet in the morning)
There was no noticeable breakup on the top end of the rpm range so I doubt that it would be valve float. The engine is just basically broke in and dynoed so the springs are fresh. The car would rev strong up to that point, but would not rev any higher. It would just stay at 5800rpm basically. We are dynoing on a mustang dyno loaded. We dynoed with it unloaded but it didn't really change. Fuel system is up to snuff with -10 feed and -8 return with 90lb fic's with 4303 magnafuel Fuel pressure set at 60 with boost reference of course. What do you guys think it could be? I'll try and post up a short video of a run to show what it sounds like. I'll have to check with my tuner to see if he has any logs saved on the run. Kinda lost at this point. We've come up with 2 possibilities. a. speedo tables need to be scaled so the speedometer is reading double speed and we could possibly be hitting the speed limiter in the stock parameters or b. he thought we might be running through the converter. I question the converter thought since there isn't an rpm rise. It stalls at 5800 rpm. If the converter wasn't holding (locked) it would act like a slipping clutch since that is essentially what would be going on correct? I also question the speed limiter because while I'm driving it on the "racetrack" I hit that speed limiter and it knocks everything down immediately so I wouldn't think that it would just hold the rpms on the dyno. Any educated input would be appreciated. Thanks Chris
Old 05-12-2014, 12:09 AM
ta02zx10r's Avatar
well go figure.... I can't send the video because it isn't the right file or some crap can't send it from my phone because a token is lost or broken blah blah blah works about as good as the search function on here lol
Old 05-14-2014, 05:36 PM
ta02zx10r's Avatar
Lol anyone got any ideas. I figured this would be the best spot to park this thread but if it needs to be in tuning please move it mods.
Old 05-14-2014, 05:47 PM
stevieturbo's Avatar
Will it rev with no load on the engine ?
Old 05-14-2014, 08:20 PM
ta02zx10r's Avatar
Yes we did a pull with the dyno unloaded and it revved to 6500 but he still felt like it was "lagging"
Old 05-14-2014, 08:25 PM
ta02zx10r's Avatar
I'm curious to see if it's speed limiter involved. How does the stock limiter "limit" the car? Pull timing or fuel (I hope not) ? Didn't see any lean conditions. Rpm just held solid at 5800 with the dyno loaded.
Old 05-15-2014, 12:32 AM
8 Second Truck Club
Blown06's Avatar
Could it be that your starting your pull too low (rpm) and the converter is flashing? Thereby it's "hanging up" till the tires catch the engine. I've seen that before.
Try starting the pull much higher (rpm).
Old 05-15-2014, 12:36 AM
ta02zx10r's Avatar
It shouldn't flash if it's locked up though should it? Haven't got a lot of experience with a stalled car. This is actually my first stalled automatic. Could you explain how the car acts when the converter is flashing past it's stall speed?
ta02zx10r's Avatar
lol dang I feel like a newbie now
Old 05-15-2014, 09:02 PM
underpressureWs6's Avatar
My car was doing the exact same thing on a dynapak dyno, the shop told me it was my intercooler setup becoming a restriction up top in the rpm band, rpm lvl 7 4l65e with a yank 3400, i now switched to a large frontmount so we'll see what happens now...
Old 05-15-2014, 11:47 PM
ta02zx10r's Avatar
Dang, I hope that isn't the case. I have a vertical flow intercooler so I would think that be efficient enough. This is like a "stop it in it's tracks brick wall." If it is getting restricted it should probably still rev to redline though. It won't make the hp that I would expect but the engine is still getting air.
Quick Reply: hanging rpm on dyno
