Pics of engine refresh at Don Lee Auto
Old 05-17-2004, 01:08 PM
Bad30th's Avatar
Default Pics of engine refresh at Don Lee Auto
Big thanks to Rob and Tim at Don Lee Auto ! Last week the 30th went in for a quick refresh :
- new ARP rod bolts, inspect main and crank bearings
- new ARP head studs
- new JWIS timing chain
- new Erson valvesprings
- ...and a couple of other small things
Here are some pics :
Read more here :
Don Lee Auto engine refresh
Thanks again Rob and Tim @ Don Lee's !
Happy driving,
Rob (Bad30th)
Old 05-17-2004, 03:33 PM
jrp
SN95 Director
jrp's Avatar
sweet .
totally off topic but hows your timing and tune w/ 11.1:1 CR and 91 octain?
Old 05-17-2004, 03:40 PM
Bad30th's Avatar
I've been adding a gallon or two of VP Racing 103 unleaded to each tank for a little boost.
It runs around town fine on 91 octane.
The tune is set at a semi-conservative ~26 degrees max timing, but was seeing up to 3.5 degrees of retard at WOT on pump gas before the engine refresh. I haven't re-AutoTapp'ed to see the timing with the race gas (just got the car back Friday), but it feels like the power is back. I think it may have lost a little timing from reduced cc's from combustion chamber deposits and PCV blow by deposits. I recently added a Greddy catch can so those shiny pistons should hopefully stay that way.
I'll log some more scanning this week.
Thanks for asking.
Rob (Bad30th)
Old 05-17-2004, 04:00 PM
highgear's Avatar
What did they charge $$$ for all that?
Old 05-17-2004, 04:16 PM
Bad30th's Avatar
They're very reasonable, give Tim or Rob a call at (909) 989-1573.
Their website is http://www.donleeauto.com
Happy driving,
Rob (Bad30th)
Old 05-17-2004, 06:33 PM
badls1's Avatar
Should of done forged bottom once it was all apart, specially your on a bottle.
Old 05-18-2004, 12:07 AM
jrp
SN95 Director
jrp's Avatar
Thanks for asking.
Rob (Bad30th)
who did your tune? i plan on running compression around the same as you and im worried about my timing and tune on 91.
Old 05-18-2004, 09:24 AM
Bad30th's Avatar
I thought of that and I asked about it, but the extra 2k+ for rods/pistons/rings/machining/labor wasn't in the budget.
If/when I build my next motor it will be bigger cubes AND forged. This refresh is just to make sure this one doesn't pop anytime soon.
I also rarely use the nitrous.
Rob (Bad30th)
Old 05-18-2004, 09:26 AM
Bad30th's Avatar
Mark@AAP did the tune, rest his soul... ...and it's locked... ...and the original LS1Edit flash file can't be located...
If I need to make changes I will unfortunately have to start from scratch (or implement an external fix like a MAFT or Timing Tricker).
Bad30th
Old 05-18-2004, 11:47 AM
strokedls1's Avatar
Tuning for 11-1 compression is a piece of cake. Not a big deal at all, you will just lose a little timing accross the curve if you have any detonation.
