Tps and tach on 98
Old 05-14-2014, 03:40 PM
CNTLSE 1's Avatar
Default Tps and tach on 98
Working on wiring a tick performance dual stage window system in my 98 trans am. I have basically drawn my own wiring schematic from a couple I have seen. My only question is on what wires do I need to connect the tps (blue) and tach signal ( green) wires coming off the window switch on my car? Can the blue wire just be wired in with the wot switch that will be going in as well? Thanks for any help. Searched and couldn't find exactly what I was looking for
Old 05-14-2014, 04:12 PM
brandon@nitrousoutlet's Avatar
Tach Wire: Passenger side of vehicle – Main coil harness plug – Top row of wires – second wire form the left OR Pin 10 @ pcm on Red Connector
TPS Wire: Pin 8 @ pcm on Blue Connector
You can run the wot switch with it as well if you don't want to run the TPS.
Old 05-14-2014, 05:16 PM
CNTLSE 1's Avatar
Perfect thank you
Quick Reply: Tps and tach on 98
