Road Racing Road Course | Autocross
5th Gear on the track
Old 05-15-2014, 10:42 AM
Midnight02's Avatar
Default 5th Gear on the track
Forgive me if this sounds like a stupid question...
I heard from a buddy (which doesn't necessarily mean it's correct) that it's not good to go WOT in your overdrive gear(s).
Do you 6-speed guys have any concern with running WOT in 5th gear on the track?
I realize that 3.42 is arguably the ideal rear gear ratio for a road course (from a versatility standpoint), however I still have 4.10's in the rear. Anything over 125 mph and I'm getting into 5th for a while on the higher speed tracks.
I'll eventually change it, however the 4.10's will be in there for my next few track days.....one of which will be on the banked oval at Atlanta Motor Speedway. Knowing I'll have plenty of time there above 125 mph I just wanted to understand if that will cause additional stress to the tranny.
Old 05-16-2014, 10:36 AM
1981TA's Avatar
We're hitting 5th at road america on the big stretches, and we have 3.42s. We got to 5200 RPM aproaching turn 1.
Old 05-16-2014, 03:28 PM
Arctic2002ss's Avatar
I was going to 5th the last time I was at Texas World Speedway. No problems.
Old 05-16-2014, 05:00 PM
79_T/A's Avatar
I've always wondered how my car would feel swapping from 3.42 to 3.73 and using the mn12 gear set with the shorter 5th gear so the car would pull in 5th. It would accelerate quicker for sure, but the more important question is would I be shifting too much and nullifying the gains. For what it's worth, speeds for 4th and 5th gear with that set up and a stock height tire would be 132 and 157 at 6500 rpm.
Old 05-16-2014, 09:26 PM
Midnight02's Avatar
Thanks for the input guys.
Food for thought with the mn12 setup. I love my 4.10's on the street, however they are far from ideal on the track. Will eventually change it out....just not at the top of the list.
Old 05-18-2014, 09:52 AM
FASTFATBOY's Avatar
You have the M12 trans?
Lucky bastid.
5th in that trans is better than the T56, less drop.
I would pull that 4.10 and go back to a 3.42.
Old 05-19-2014, 08:59 AM
Midnight02's Avatar
Lucky bastid.
No, I don't have the M12 trans -- wish I did.
3.42 seems to be the way to go. The 4.10's are awesome on the street but are way too busy on the track. Now that I actually know how to drive several of the tracks around here I believe eliminating those extra shifts would knock seconds off of the lap times.
Old 05-19-2014, 09:12 AM
FASTFATBOY's Avatar
Old 05-19-2014, 09:18 AM
Midnight02's Avatar
Sorry, I should've been more clear. That line in my reply to "79 T/A" should read something like this...
"The info you posted above regarding 5th gear in the MN12 is good to know. Now my desire for the M12 gear set is just one more goody on the long-term "want list"."
Old 05-19-2014, 09:26 AM
FASTFATBOY's Avatar
Gear choice in these cars. We have enough power/torque to get around a track even in stock form using 3rd and 4th.
Only one track around me I got to 2nd gear, the corner is 120*. When I get on the gas it destroys the rear tires. 3rd is probably faster I bet, but its fun.
3rd and 4th with a 3.42 will get you around 99% of all tracks.
This is a fun little track in La. Made for Miata's and 944's, not my turd.
Quick Reply: 5th Gear on the track
