FINALLY! headed to the dyno. 347 mid frame 78
Old 05-18-2014, 02:13 AM
yelo04goat's Avatar
Default FINALLY! headed to the dyno. 347 mid frame 78
well after this taking far to long to get finished the car is wrapped up sitting nice and sexy on drag radials and factory wheels. sleeper status
she is headed to the dyno at CMS in southern CA. weather should be reasonable where there too headed in on the 22nd..
here is a run down of the build
MOTOR
forged 347 LS6 bottom end -11cc wiseco pistons eagle rods stock crank
VA speed turbo cam VTC2 23x/22x and .600ish lift.
AFR v2 230 heads 65cc chambers
ls6 intake ported ls1 throttle body
127 lbs @58 psi injectors mast fuel rails
holley billet pump
DRIVETRAIN
newer core 4l80e built to handle 800+
circle D muiltidisk billet verter stalled at about 3200
gforce1320/PTS 3.5 alum driveshaft and full built gforce rear with trutrc and 3.46 gears
TURBO SETUP.
turbonetics midframe 78mm T4 with 1.14 ar 75mm F1 turbine and big comp cover similar to the y2k unit
turbosmart raceport 52mm BOV
turbosmart 50mm wastegate.
will have 2.25 in to 2.5 crossover 4'' down pipe cutout and full 4" exhaust.
E85 tune up
10-12 lbs low
20-22 lbs high
mustang dyno.
power guesses?
trying to set the stock cube turbo GTO record.. from what i have found that 9.70 right now..
Old 05-18-2014, 09:12 AM
JAX04's Avatar
best of luck, in for numbers.
Old 05-18-2014, 09:37 AM
Red89GTA's Avatar
Sounds like a solid build, just for fun, I'll say 637hp
disclaimer: that is a off the top guess, did not think too hard, and I am generally horrible at guessing these sort of things. Hopefully its what you need!
Old 05-18-2014, 01:20 PM
yelo04goat's Avatar
thanks guys.. we will see
Old 05-18-2014, 06:36 PM
1bdbrd's Avatar
Can you provide more details on the bigger comp cover? Was it a simple bolt on? I am assuming the turbo is basically the same otherwise to the standard 7875 that some here are running correct?
Old 05-18-2014, 08:18 PM
Ryans99ls1's Avatar
youll be fuel system limited to 900-1000hp so im going to say it makes upper 800s but only cus of the 80e..
Old 05-18-2014, 08:19 PM
Ryans99ls1's Avatar
youll be fuel system limited to 900-1000hp so im going to say it makes mid-upper 800s but only cus of the 80e. Im also assuming you will not wimp out on the tune and let it rip
Old 05-18-2014, 11:55 PM
yelo04goat's Avatar
its the turbonectics mid frame i think the center section is shared with the y2k turbos and the comp cover is similar to the y2k its a fairly good size turbo weighs about 40 lbs here is a picture of it for size comparison
really think the pump will limit me on e85? i figured the turbine will be the limiting factor before the pump.
Old 05-19-2014, 12:19 AM
95bowtie's Avatar
Where's the build thread?!?
When a gto gets a turbo it must always have a build thread.
Idk how well that pump you have flows but I'm going to have to say the 75mm turbine is going to choke up before your fuel runs out more than likely.
Should have sold that turbo off a long time ago and got the smaller 7875 version. Would have been easier to package for whoever did the fab work that's for sure. They both will make the same power since they use the same wheels.
Old 05-19-2014, 05:43 AM
JAX04's Avatar
Where did you stick that turbo at in this car? Lets see some pics.
Old 05-19-2014, 07:36 AM
Ryans99ls1's Avatar
Idk, mine is very happy at 16lbs and we have the same size motor. I plan on maxing this turbo out when i go get retuned, so im expecting to hit 20-22lbs as well. Should be mid to upper 800s but im 6spd so my numbers may "look" better.
My 80lb injectors (58psi base) were maxed at 16lbs and the dual 255s were going to be next. I'm not familiar with that holley pump but you may be close, your injectors will be fine.
Guess i assumed you had a bigger turbine when i glanced over the build, oops. That 80e is gonna rob of you high(er) numbers but the car should fly on high boost.
Old 05-19-2014, 09:48 AM
thendawg's Avatar
Which holley billet pump? If its the 1800, it should get close to 900whp on E85 through an auto. Id guess that turbo would also start falling off around 850-900. So my guess would be in that range if you push it til you run out of fuel or turbo. Also, any pics of the build? Love to see other GTO turbo setups! Im getting ready to start on my 06 GTO 5.3/S475/M6 build. PLan on starting a thread once I get the motor together and start building the manifolds.
Old 05-19-2014, 11:09 AM
93camaro_zzz's Avatar
Good luck Travis! I am thinking it should make every bit of 800whp on the higher boost. The locking torque converter will help you out as well! Wish mine could do that! haha
-Jordan
Old 05-19-2014, 11:50 AM
67Firebird455's Avatar
Travis - I'm guessing 327rwhp. JK, you're breaking 800 bro, I can almost guarantee it.
Old 05-19-2014, 06:53 PM
yelo04goat's Avatar
yea its the 1800 pump.
i only plan to go bigger so this turbo will allow an s400 to almost drop right in being they are similar in size.
and now for a few picsFINALLY! headed to the dyno. 347 mid frame 78-gtot1.jpg
Old 05-19-2014, 06:55 PM
JAX04's Avatar
more pics!
Photobucket is your friend
Old 05-19-2014, 07:03 PM
yelo04goat's Avatar
no time for pics LOL
tuts what you get
Old 05-19-2014, 07:04 PM
JAX04's Avatar
Plenty of time for pics! Email them to me if you have too
I hate clicking pics haha
Old 05-19-2014, 07:07 PM
yelo04goat's Avatar
i really dont have many.. wasn't worried about a build thread or anything took a few but really wasn't worried about it..
JAX04's Avatar
So you dont have to click one image at a time, because it bugs the **** out of me hahaha
Quick Reply: FINALLY! headed to the dyno. 347 mid frame 78
