low oil pressure/bearing issues?
I was making some pulls the other day and noticed my oil pressure was acting strange. It would creep up with rpm to around 50psi, but then drop and settle around 40psi. Hot idle then dropped to 20psi. I did an oil and filter change today and it started up with 26psi cold idle... :/
6.0 with a melling high pressure/high volume that used to make a lot more pressure.
http://vimeo.com/m/95614840
I'll pick up a filter cutter tomorrow and check it out. Oil looked normal coming out but other than what I kept in the filter the rest has all mixed in my drain container
I've had issues with my clutch preloading against my throw out bearing due to too thick of stack height... Went through 2 throw out bearings about 1,000 miles each till I realized the problem (clutch didn't slip). Could those 2,000+ miles of pressure take out a thrust bearing?
Forgot I'd made this thread last year:
https://ls1tech.com/forums/generatio...-too-much.html
So even though I couldn't remember exactly where it was at, it's down a ton at 20psi hot.
So I'll probably find silver in the oil filter in a few hours?
