Corvette filter/ regulator problem?
Old 05-24-2014, 03:36 PM
fxbdydriver's Avatar
Default Corvette filter/ regulator problem?
I have lq4 with polluter cam, ls6 intake, stock injectors. Using corvette filter/ regulator. My 81 Fairmont futura ran great. Decided to pull t56 for auto. Completed swap, did retune by pcm for less,( did first tune also.) I did move my corvette filter regulator in process. Now car is running rich, plugs dark and wet. Won't stay idling. Could I have damaged regulator? Maybe may fuel pressure is too high? I have a new Holley dominator fuel pump. Should I just swap regulator?
Old 05-25-2014, 06:20 AM
Old Geezer's Avatar
Try checking the fuel psi, B4 you start throwing parts at it??
Quick Reply: Corvette filter/ regulator problem?
