NSX manual boost controller users
Old 05-26-2014, 06:07 AM
69-chvl's Avatar
Default NSX manual boost controller users
With either a 10 or 7 psi springs installed, and with the boost controller pretty much backed-off all the way, boost is very erratic. Sometimes 13psi, most of the time 17 psi. I have the s475 83/74 with 2 38mm gates. Going to remove the controller today and just reference the turbo and see what kind of control I get that way, but I cant imagine 2 38's are not enough gate.
So far though I just don't think this BC works very well, but what can you expect for $20.
Old 05-26-2014, 12:41 PM
Wicked69's Avatar
I ran that one for a while and it worked fine. Maybe the openings on the hotside needs to be hogged out where it meets up to the wastegate opening.
Old 05-26-2014, 01:55 PM
RonSSNova's Avatar
I'm just using 9 psi springs. Even though it seems to measure 11 psi, it's rock solid.
I have two 38mm Tials
Old 05-26-2014, 02:39 PM
69-chvl's Avatar
I just bypassed the controller and stuck in 11.6 psi springs and sure enough it holds 11.6 psi. I think me issue is that the controller is hyper-sensitive to adjustments, maybe their all like that who knows. I will say that boost builds a touch slower w/o the controller.
Old 05-26-2014, 03:37 PM
RonSSNova's Avatar
Are you measuring boost via the map sensor and data log or by a gauge?
In relying in the map, converting kpa to boost.
Ron
Old 05-26-2014, 05:00 PM
69-chvl's Avatar
Ron
Datalogger shows boost at 180 kpa = 11.60psi. The fuel pressure is also going to 54 from the 43psi base so the measurements are right on.
Old 05-26-2014, 07:57 PM
GTO Eric's Avatar
Something is not right.
I have the same controller on my turbo GTO and I have installed one on a twin turbo supra. Both work flawlessly.
Do you have a picture or diagram of how it is hook up?
Old 05-26-2014, 08:57 PM
69-chvl's Avatar
No pictures but its hooked up right. I needed to take it out and runs some tests, and its very sensitive that's all. I think I'll run the lightest springs I have for the gates and that way a little more tension on the controller may work better vs me trying to run the controller with barley any tension on it.
Quick Reply: NSX manual boost controller users
