LS1/S13 awesomeness! Everything to build a 400+whp 240SX track monster!
Category: Engine - Complete Motors
Price: $1
Part Fits: 93-02 Chevrolet Camaro, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): KY
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
*LS1 engine set, ~85,000 miles, MS4 cam, Patriot springs, LS7 Lifters, Comp Cams trunion upgrade, TSP Pushrods, LS6 heads/intake manifold, ported LS6 oil pump. On the dyno it made 405whp, 360 ft/lbs. $3000
*GTO T56, LS7 Clutch, Hurst shifter, ~85k miles, 15k on clutch. This trans has the shorter 5th gear than the normal F-body T56, much better IMO. $1700
*Aeromotive FPR with lines and filter for LS1 swap into S13, SOLD
*Wilwood 4 piston brakes with 350Z Track rotors (front). 300ZX rear/ebrake cables, rear 5 lug with ARP Studs, braided lines all around. (Would need stock rear spindles with hubs in exchange). Rotors are Stoptech crossdrilled/slotted, Street pads are Hawk HPS, track pads are Carbotech XP10/XP8 $1200
*Hinson headers with 3" v-bands SOLD
*Bluegrass Muffler built 3" single exhaust, all stainless, Magnaflow muffler and resonators. SOLD
*Sikky engine/trans mounts SOLD
*Sikky Aluminum S13/Non-abs Driveshaft SOLD
*Koyo KA-style radiator with Mishimoto Fans/Shroud. Gobs of cooling power, and fits with the LS1 perfectly. $500
*CXRacing Coolant overflow for S13, $50
*Wilwood Clutch master with 240sx conversion mount SOLD
*Koni/Ground Control complete kit with camber plates and rear top hats. 600/450 springs, $1500.
*Enkei RPF1's, Silver, 17x9 +35 with Nitto NT01's 245-45-17, one track day on them. $1500.
*Team Dynamics Pro Race 1.2, matte black. 17x9 +35, 245-40-17 Hankook V12's with > 50% left, no camber wear $1000
*Team Dynamics Pro Race 1.2, matte black. 15x7 +40, 255-60-15 Mickey Thompson Drag Radials with about 300 miles on them, no burnouts. $650.
*Will sell all Team Dynamics wheels as a set for $1500.
*Pieced together nitrous kit, NOS solenoids, NX plate, misc jets ranging from 50 shot to 150 shot, Zex bottle with NX 45 bottle valve, Autometer electronic gauge, NX bottle heater with pressure switch. $900
*Radium Engineering surge tank, with one Aeromotive 340 pump installed, brand new. $600
*Aeromotive 340 pump installed in the factory tank, SOLD
*Complete S13 rear subframe with Z32 R200V, stock axles, SPC UCA, traction rods, and toe links. Energy suspension subframe bushing inserts. Would need a complete roll able subframe in exchange, no diff, axles, brakes needed, just enough to hold a car up and keep it rolling. $700.
*Siemens/Deka 80lb/hr fuel injectors (8x). $350
Anyone that knows me, knows how well all of this setup runs. No expense was spared. Engine runs perfectly and starts every time. Transmission has no grinds, and the clutch has tons of meat left on it. The driveability is everything you would expect out of a stock clutch. Heavier than a 240 clutch of course, but butter smooth. Headers and exhaust have minor speed bump scrapes on them, but no dents at all. Brakes/suspension have less than 5k miles on them. Nitrous kit is simple, but works well. I had the Autronic controlling it, so you would need to come up with your own window switch, WOT switch, etc. All wheels are in perfect condition, no bends, no scratches, etc. All tires have TONS of life left in them, and no camber wear.
I'd make a deal on large packages if interested. Anyone wanting to swap an S13, this is basically everything you would need minus a computer and wiring harness. Unless otherwise noted, everything has about 5k miles on it. If you want to check anything out, my schedule is fairly open, so I have no problem showing you anything while it's still installed on the car. I'm sure I'm forgetting some things, but this is at least most of it!
Pictures of most everything can be found on my facebook page, here:
https://www.facebook.com/media/set/?...1&l=d0fc8614af
Please PM, text, or Email. Thanks!
-Blake
(502) 432-1314
blake@geektuned.com
Last edited by Drag_S14; 06-06-2014 at 02:23 AM. Reason: updated prices and sold items
