fast fuel line kit for f body
Ok guys I have been running stock ls1 fuel rails on my car for quite some time with no issues. I scored a pair of FAST rails for the ls1/6 intake. I am looking to put them on my FAST 90mm intake. I also ordered the fuel line kit from fast PN 54028-KIT and have a few questions. I will have no problem installing it but I was under the assumption that the crossover was to be installed on the front of the rails (facing the front of the car) but with this kit it seems that it has to be installed on the back side of the rails and just the feed line and plug installed on the front rails. Is there any other options for a kit to make the crossover work up front? If not no big deal, thats just what I was hoping to install.
Maybe you can answer my question...no one else has
https://ls1tech.com/forums/fueling-i...-plumbing.html
Thanks
and this one...https://ls1tech.com/forums/fueling-i...rail-help.html
Thanks
i know it is not ideal but i cut the factory metal hard line as it comes up from the firewall put a flare in it and attached rubber hose with two hose clamps and then got an aeromotive fitting with a hose end and put that in the hose in the other end of that fitting is an threads and you just screw that on to the feed line to the rails and then you can run the rails with the cross over line in front on top of the throttle body....i have never had any leaks either ....not the best at explaining it hope this helps
