Retuned after converter install
Old 05-27-2014, 09:18 PM
MN98WS6's Avatar
Default Retuned after converter install
hey guys, I am just about finished installing a yank 3600 stall converter in my 98 WS6. My question is am I going to have to take the car in and have the computer retuned for the tranny to work properly. Change shift point, idle rpm ect..?
I plan to have the car dyno tuned sometime this summer when I have everything complete, so I don't really want to have to do it twice. This is the first time I've put a high stall converter in a car so its kinda new to me.
Thanks
Old 05-28-2014, 07:17 AM
01ssreda4's Avatar
It should drive fine with little to no issues. Your shifts will feel very soft now, and your shift points could probably use a little tweaking but it will get you around fine.
Old 05-28-2014, 09:34 AM
DANOZ28's Avatar
i dont know much about them but search "shift extentions". i read that over a 3300 stall the pcm can feel like its slipping but not sure what computer mod fixes that.
Old 05-28-2014, 02:18 PM
01ssreda4's Avatar
I've never personally thrown a fault code on WOT for shift extensions, but part throttle can be tricky because lots of times rpms don't drop after the shift, and the computer deems this a non-shift.
Old 05-29-2014, 10:42 PM
Pontiacerator
RevGTO's Avatar
Yes. You will want to bump up your line pressure for firmer shifts, raise your shift points, decrease your shift times, possibly eliminate third gear lock-up, adjust your lock-up speed, and tune out trouble codes that will throw the trans into limp mode.
But you will probably be ok waiting a couple of months and driving it with the stock tune before you get it dyno tuned.
Old 06-02-2014, 08:53 AM
tnmotown's Avatar
Yeah you'll be ok to drive around. I just wouldn't recommend going WOT.
Get it tuned asap though, it makes a world of difference driving
Old 06-02-2014, 08:59 AM
senicalj4579's Avatar
I did not get a tune for my ss3600 until a month or so after breaking it in. I gave it hell before a tune no issues. After I got the tune I couldn't even tell a difference. Just make sure you break it in. I think its 150 miles.
Old 06-03-2014, 02:33 PM
DANOZ28's Avatar
may i ask what specifically did you have adjusted in your tune? thx
Old 06-03-2014, 02:40 PM
redtan's Avatar
There's nothing wrong about going WOT without a tune. It's not like you have to adjust fueling and spark tables for the new converter.
You should at the very least adjust the up/downshift and lockup tables. Line pressure is also a good thing to play around with.
Quick Reply: Retuned after converter install
