building 6.0 around vortech t trim supercharger
I have a vortech t trim which is comparable to a d1sc procharger. I am going to run a ls6 top end and send my 243 heads into AI for porting and polishing. my block choice is 370,390,408 I would like input on what block is best for this supercharger. I aiming for 800whp on pump gas. so this means I will have to run meth most likely. should I mill the 243s at all? I understand 800 may be a stretch for this supercharger
I just know going being cubes I would be putting less stress on the sc so I thought it may be easier to hit 800whp that way but I was looking at the 390 as my number one choice. what about milling the heads? thank you for your help
I wouldn't mill the heads. Why would you want to do that?
Pick the desired compression of the motor with the cc chamber size of your heads in mind. Piston selection will allow the choice of compression. That way it's right. With an FI setup you don't want to take any more meat off the deck of the head. You want it as thick as possible for less of a chance of lifting a head and it leaking, especially at the 800 hp level.
Go with either a 370 or a 390 depending on the budget. A 370 is a little bit cheaper or find a deal on something like an AES 390. Go with a reputable builder regardless.
