Ring Gap
Ring Gap
Wanted to get some recommendations for ring gap...
Street/strip. Would like to turn the boost up quite a bit when racing.
5.3 (3.78 bore)
Trick flow 220's
wiseco pistons GFX rings
Lunati billet rods
S480 V3 billet wheel
LJMS cam
6spd
5.3 (3.78 bore)
Trick flow 220's
Lunati billet rods
LJMS cam
6spd
I gapped Wiseco piston/ring set at .026 top ring, .030 second ring. Second ring is gapped larger so as to prevent ring flutter. Currently going to spray it but possible big boost later.
Yes, ring gap is a function of bore size and the manufacturer makes recommendations but there are proven formulas from experienced boost engine builders as well that I trust for a build such as this. Ring gap will close quite a bit under big boost and I would rather err on the side of safe. Do your homework OP and make sure to talk some knowledgable boost engine builders.
