Read this plug please
Old 05-31-2014, 12:41 PM
RonSSNova's Avatar
Default Read this plug please
This is a TR6, turbo on E85.
11 psi, 14 deg timing, 10.8:1 AFR
I want to turn the car up a few psi. But maybe need a different plug?
I know, BR7EF
I kind of like projected tip plugs though. Was thinking maybe Autolite AR103, or AC R42XLS. Both should be colder, but the cross references are fuzzy at best!
Old 05-31-2014, 12:46 PM
jaybuller's Avatar
you need to cut it so we can see the fuel ring area... also just from the fuzzy picture i see what looks like possibly detonation specks on the strap. but could just be the picture. did you do this run at wot then cut the car off and drift over and immediatly pull the plug? or has this been run normal driving after the hard run?
Old 05-31-2014, 01:07 PM
RonSSNova's Avatar
After a 1/4 mile run at the track. And driving it home.
Car has a TH400 trans, it's not advisable to shift to neutral from high speed. Also don't think the turbo would like no oil pressure right after full boost.
I understand a clean cut is best, just not going to happen.
Knock sensors are working, it shows no detonation.
I was mostly interested in the position of the heat line on the gnd strap.
My reading says it indicates too much timing. At only 14 degrees, I don't think so.
Plugs are virtually new.
Ron
Old 06-01-2014, 12:24 AM
8 Second Truck Club
Blown06's Avatar
Well if you have drive time on it, it's near impossible to get a read.
Old 06-01-2014, 03:06 AM
RonSSNova's Avatar
Caught ya over on YB. Agree, I didn't look at them till after some drag runs.
Old 06-01-2014, 03:25 AM
john.boy1985's Avatar
This!!
Old 06-02-2014, 01:29 PM
Forcefed86's Avatar
Too hot of a plug combined with too much timing for that plug maybe? E85 doesn't' foul plugs. Aside from plug fouling, what is the advantage of a hotter plug? Everything I've ever read also indicated extended tip plugs are a "no-no" with boost as well. Why would you want ground strap any farther into the CC than it had to be?
My LS 5.3 setups didn't like a non-resistor plug (AEM Ecu) so I'm pretty much stuck with a BR7EF.
My 4cyl runs 34psi on E85 and I run an NGK 9 heat range plug with no fouling. I ran a 10 heat range in my buick 3.8 at 28psi on E85.
Personally this is what I like to see for a heat line on a turbo plug running 20+lbs.
This is more how the BR7EF looks on my LS at 20lbs.
Then you can go the extra mile and cut the ground strap down so it's even less prone to detonation like the pic below.
Old 06-02-2014, 02:03 PM
LS1 240sx's Avatar
Would you have spark blowout issues if you cut the ground strap down like that?
Old 06-02-2014, 02:48 PM
Forcefed86's Avatar
No, the gap would remain the same. It’s called “side gaping” Bunch of info on it if you do a search. Lots of race plugs come with the strap pre-cut like that.
Old 06-02-2014, 03:54 PM
RonSSNova's Avatar
I responded and it didn't come through.
I ordered the BR7's
Ron
Old 06-02-2014, 08:52 PM
bh353's Avatar
You need to look way down inside the plug..there should be a 1 to 1 1/2mm carbon ring at the bottom of the electrode base..
Old 06-02-2014, 09:20 PM
RonSSNova's Avatar
With a microscope, I see some black specs on these.
I'll be sure and keep tabs on the new ones.
Old 06-02-2014, 09:32 PM
Forcefed86's Avatar
Not a very defined fuel ring with e85 usually. All information is good information, but that pretty old school tuning IMO. You could find your leanest cylinder this way, but I can usually tell that by the base color on the plug face without cutting the threads off. You have your WB02 to tune the fuel with mainly. I pay the most attention to the strap. It gives you your heat/timing info and is the main concern.
Old 06-03-2014, 09:05 PM
RonSSNova's Avatar
Got the BR7's today. I'll put them and see how they run.
I sure hope they don't mess up the idle/low speed operation with the gap hiding way up in the chamber. But you all say they work.
I noted the side gap on the race plugs my builder showed me that they run in their circle track car. NGK, extended tip 9 heat range. Non resistor.
Ron
Old 06-04-2014, 09:46 AM
NorthTexasConverter's Avatar
I know some local cars that drive around on -8s or colder, with no issues.
Quick Reply: Read this plug please
