Turbo headers
Turbo headers
Has anybody ran something like these? Price seems too good to be true.
http://www.ebay.com/itm/LS1-LS6-LSX-GM-V8-Chevrolet-Forward-Dual-Turbo-Headers-Manifolds-Header-Manifold-/261379110472?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cdb68b648&vxp=mtr
If you do a search, I think someone modified them to fit with factory accessories. Not sure of quality, but can't beat the price.
Edit: here's the link
https://ls1tech.com/forums/forced-in...ldnt-done.html
I have a build going right now using these headers. They had to be modified but they are looking beautiful. Quality was great. Here's the link.
https://ls1tech.com/forums/forced-in...-trans-am.html
Here is the modification to those headers to make them fit.
The question i have is
A: how long are they?
B: how wide are they From mounting face of the head to the widest point?
For my particular application size is the biggest concern and it seems impossible to get any questions awnsered from the supplier
On the length part, I know they are different sizes when mounted to the head bacause one is closer to the front than the other due to exhaust port spacing. I will dig to see if I have some pics with a tape measure. Also I have an email somewhere when the seller contacted me. I will hunt it down and post back shortly
"Hello,
Flange is 1cm.
pipe thickness is 1mm.
Thanks
Beasy"
That's all the info I got from him, but if I remember correctly, it was 5" on one side and 6.5" on the other side and thats how long past the head. Width I believe was 5" from the head to the top outside of the header. Keep in mind I ordered 1 7/8" primary headers with a 3" collector. Its now been reduced to a 2.5" collector
Flange is 1cm.
Thanks
Beasy"
Yes, I seen that. but the thickness is closer to 16 gauge. I bought the master builders kit from mandrelbends.com and the pipe thickness was the same. That kit was 16 gauge 304SS. Also I would highly recommend putting solid motor mounts in and mounting the turbos to the frame.
