Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Which CAI when installing a FAST on a 2000 C5
Old 06-02-2014, 02:26 PM
jodyjo's Avatar
Default Which CAI when installing a FAST on a 2000 C5
Basic question is how do I mate my stock air intake fit the bigger LS2 throttle body? Thanks.
Old 06-02-2014, 11:56 PM
Silver408z's Avatar
What size Is your fast? Are you boosted?
I personally have a 102 and I NA. I had to get a piece of silicon that was not reinforced with the threads inside it. The silicon was 4" and the 102 is like 4.25". Since the silicon was not reinforced it would stretch to fit the larger diameter of the intake and still be small enough to fit the other tubing. I have a 4" diameter aluminum short spacer to fill in the gap from the intake to the intake bridge. If you are boosted you will most likely not be able to use a piece of silicon that is not reinforced. Being NA I don't collapse or explode the silicon that is not reinforced. There are places online that sell stepped silicon connectors. Do some googling and I am sure you will find them. They are not cheap either.
Old 06-03-2014, 07:04 PM
jodyjo's Avatar
Thanks for the help, I'll check into that. It's a 92mm intake.
Old 06-03-2014, 08:18 PM
Lowmiles's Avatar
I used the vararam, my brother has the black wing with the vararam bridge.
Old 06-04-2014, 06:04 AM
01Z0H6's Avatar
Home Depot.... They sell different couplers that work just fine.
Quick Reply: Which CAI when installing a FAST on a 2000 C5
