Finishing up piecing a kit together.
I just picked up a few items off the classifieds here, and want some opinions on what else I should buy before starting the install. Pretty much completely new to nitrous fyi.
NX 20118-10 kit: Mostly there, missing a few small things that I am getting from Garrett on Friday (Was missing nozzle bung, 150 jets, bolt kit). This kit has the lightning solenoids, WOT switch, shark nozzle. Bottle needs recert.
Racetronix pump & hotwire kit
HSW Microedge
I already have a pressure gauge & bottle heater. I am leaning towards mounting the bottle in the spare tire well.
Current engine mods on the car: AI LS6 heads, 235/242 111+3 cam, 1 7/8 Kooks headers with 3" x-pipe dumped, Fast 92, 92mm TB. 36lb FAST injectors 10.8:1 compression
Looking for opinions on what accessories I should pick up, planning on getting a purge, and a blowdown tube. Curious as to what spark plugs to switch to as well. (150 shot is the plan). Anything else I should take a look at?
HSW Microedge
Most here will recommend the BR7EF non projected tip plug. The TR6 was the nitrous plug back in the day, but the BR7EF is considered to be the choice of most for 150 shot and less. As you increase from there, you can step to a 9 and even higher (colder) heat range plug. Try those plugs and let us know what you think. I am having some misfiring issues on those plugs but am certain its other issues causing that, which I am correcting now.
Ls1tech & Truck Sponsor
HSW Microedge
HSW Microedge
I would recommend you using the NGK BR7EF's for plugs as well.
Trey
i dont know what the hsw microedge is i assume a window/wot switch. may wanna look in to pulling timing out, not mentioned in ur op, if not tuning it on the kit the lnc2000 is plug and play and keeps it safe.
