FAST 102 TB Vs NW 102 TB
Old 06-04-2014, 01:00 PM
Patsy57's Avatar
Default FAST 102 TB Vs NW 102 TB
Hey guys got the fast 102 TB for an NA 02 Transam with 430 LSX and FAST 102 intake car that will have an F1r. Just curious do you prefer the FAST 102 or the NW 102 TB? I have both and im not sure which I should use. Let me know your thoughts.
Thansk!
Old 06-04-2014, 01:24 PM
Restricted User
JoeNova's Avatar
More than likely, It is going to make absolutely no difference, and you'll never be able to tell one from the other unless you popped the hood.
Old 06-04-2014, 01:30 PM
Patsy57's Avatar
no sticking getting under boost with either?
Old 06-04-2014, 01:34 PM
Restricted User
JoeNova's Avatar
You think that one 102mm throttle body is going to make that much more power than another 102mm throttle body? Both if them will flow more than enough, and therefore neither is going to be a restriction.
Old 06-04-2014, 01:38 PM
Patsy57's Avatar
Not worried about the power just worried about sticking really under boost. My issue is my FAST unit sounds like a massive VAC leak... So I was going to go with NW which I also have but have read some things about issues under boost so im not entirely sure...
Old 06-04-2014, 08:29 PM
I8UR4RD's Avatar
shouldnt matter either way, but i was always under the impression that the work done by NW was better than FASTS. better idling and what not for a 102.
Quick Reply: FAST 102 TB Vs NW 102 TB
