1999 trans am ws6 6speed
Year: 2016
Make: Pontiac
Model: Trans Am
Price: $15500
Mileage: 96
Private or Dealer Listing: Private Listing
Location (State): OH
Color: Blue
Transmission: Manual
Drivetrain: Rear Wheel Drive
Motor is around 10,000 miles all documented
Machined Ls1 Short Block
Custom Grind Cam From Tracy Scott @ Cincy Speed -.617/.622-114LSA Camshaft
CNC Machined Ported 243 LS6 Heads
Ls7 lifters.
ARP Headstuds
01 rods and pistons.
Polished crank.
Ported ls6 oil pump.
Brian Tooley Race DBL Valve Springs
Titanium retainers and locks.
Chromoly Rods.
SLP Lid
Pacesetter headers
Texas speed y pipe
Electric cutout
Magnaflow Catback.
Just Dyno Tuned by Tracy Scott @ Cincy Speed 415/398 Car will be getting tuned for speed density should pick up close to 435 to the rear tire.
Roughly 8k on Tick Built Transmission.
Ls7 clutch
Tick performance master cylinder kit.
All new gears syncros, and forks except reverse. Zo6 spec'd.
Suspension.
Hotchskis rear kit (sway bar, lower and upper control arms, panhard bar) bmr weld in subframe connectors, bmr torque arm, eibach pro-kit with coils and struts. Drilled and power slotted rotors.
Chromoly 28 spline axles. Eaton limited slip. Richmond 410 gear.
Brand new c6 zr1 wheels 18x9.5 in rear wrapped in 275 45 18 nitto 555's. 17x8.5 in the front wrapped in 265 45 17 falkens. New ws9 hood.
Interior has leather. Pioneer head unit. All pioneer speakers. Jlb 10" sub hidden in hatch with jlb amp. T tops don't leak. They come with shades and it has a holder for them in the hatch.
Call or text dean at 513-393-1076
