Fuel Pump Question??
Old 06-04-2014, 08:46 PM
CarrBoost83's Avatar
Default Fuel Pump Question??
Iam trying to decide on what type of fuel pump to get, i will be getting a set of 60lb injectors and running a s475, not going to be running tons of boost, 8-12 ish. engine is a l33 returnless fuel system if any more questions about the setup just ask. iam curious as to what i need for a pump,also want to run an external.thanks.
Old 06-05-2014, 04:24 AM
stevieturbo's Avatar
Engine is less relevant than current tank/lines/regulator/rails setup.
What have you got already ? Or starting from scratch ?
Old 06-05-2014, 05:51 AM
Restricted User
JoeNova's Avatar
Only 60 lb injectors? I'd get a walbro 400.
Old 06-06-2014, 09:27 AM
iam trying to keep the engine bay looking completely stock,besides the charger obviously,but stock rails,i have a cell and will be running that,was looking at an A1000,and rolling with the regulator that coinsides with the a1000, but still looking, so to answer your question even better, iam starting from scratch, except wanting to keep the stock rails.
Old 06-06-2014, 09:28 AM
ill take a look,thanks.
Old 06-06-2014, 09:54 AM
Walbro 400 is in tank only.
Basically you'll need to use a fuel pressure regulator local to the rails. Ideally you would pump through the rails and then into the regulator and return. But if you wish to retain the OEM dead end rails without modification, mount the FPR local to the rails instead, and again add a return from the reg back to the tank.
A1000 should be fine and cover a fair bit of power.
Old 06-06-2014, 10:26 AM
cool,since the fuel system is returnless do i still need to run a return out of the regulator? or just plug the return side of the regulator? and thats where i planned on putting the regulator as close to the rails as possible. thanks agian,any info is helping the issue.
Old 06-06-2014, 10:32 AM
OEM is returnless because the regulator is in-tank. So whilst the external part is returnless, strictly speaking there is still a return as far as the overall system is concerned.
Yes you must have a return from your new " external" regulator.
Run a 1/2" -8 feed from pump to reg and 3/8" -6 return and that should cover you for a fair bit of power.
Then -8 or -6 from regulator to rails.
Old 06-06-2014, 11:08 AM
sweet thats the info i needed.thanks alot.
Old 06-06-2014, 06:35 PM
Restricted User
JoeNova's Avatar
A bosch 044 is a LOT cheaper than an A1000 and is good to ~700-750 whp.
Old 06-06-2014, 06:45 PM
044 is a great pump, and compact. Can be used internal or external.
But 750whp ? Only in the US does it support those sort of numbers. In UK, 700 crank would be the absolute limit.
On average they do flow around 250-280lph at normal working pressures you'd expect in a boost efi application, and maintain this sort of flow right up to around 100-110psi
I would choose the 044 over the A1000 too if it can meet your needs ( hence I run a pair of them )
Old 06-06-2014, 07:08 PM
Restricted User
JoeNova's Avatar
Denmah made 721 on a stock 044. I've seen someone else make 744whp with a single 044 with 160 lb injectors and a low 44 PSI base pressure.
Quick Reply: Fuel Pump Question??
