Who make the best quick disconnect?
Old 06-09-2014, 10:53 AM
ragtopz28's Avatar
Default Who make the best quick disconnect?
Where to buy "best" 3/8 to -6an fuel quick disconnect
Thanks,
Old 06-09-2014, 07:02 PM
Mike 02T/A's Avatar
I'm looking into the Aeromotive, around $35-38.
Old 06-09-2014, 08:09 PM
ragtopz28's Avatar
http://www.jegs.com/webapp/wcs/store...ick+disconnect
Heard bad things
http://www.summitracing.com/parts/ear-991966erl
Don't know about this one
Where are you finding the Aeromotive?
Old 06-09-2014, 10:27 PM
1bdbrd's Avatar
The Earl's one from Summit looks interesting because it appears to have a second lock on it that fits on the outside. Wonder how well that works as a backup?
Old 06-09-2014, 11:51 PM
high impact's Avatar
I didn't realize the issues these adapters caused people when I bought mine and simply stumbled upon a good one. I couldn't find what I was looking for in the summit catalogue so I called them and they sent me a fitting that adapts my 3/8 quick connect line to -8, it saddles the ridge on the line and then screws together and can not come off like the ones linked above. I can't tell you the part number or manufacturer but I can tell you that a better fitting is available at summit. I will check my build thread and see if there is a picture of it
Old 06-09-2014, 11:57 PM
https://ls1tech.com/forums/nitrous-o...ous-build.html
Zoom in on the fourth picture in the first page and you can see the fitting on my stock line. It unscrews into two pieces, the lower piece saddles the line and then you screw the top piece on. Works perfectly and no chance of blowing off
Old 06-10-2014, 01:01 AM
8 Second Truck Club
Blown06's Avatar
I've been using the same "Jiffy-tite" disconnects on my transmission for a little over a year. Trans has been in and out 5-6 times, and I have not had an issue.
Old 06-10-2014, 02:17 AM
Ollie8974's Avatar
This is the style Russell fitting to use.
The U shaped part threads into the back of the fitting forming a positive lock, locking the fitting on the line.
These are available from Summit in various sizes, blue or black color.
Use key words "Russell Push-on EFI Fittings".
http://www.summitracing.com/search?S...EFI%20Fittings
Attached Thumbnails Who make the best quick disconnect?-new-style-screw-lock.jpg   Who make the best quick disconnect?-step-1-russell-efi.jpg   Who make the best quick disconnect?-step-2-russell-efi.jpg   Who make the best quick disconnect?-step-3-russell-efi.jpg   Who make the best quick disconnect?-assembled-russell-efi-fitting.jpg
Old 06-10-2014, 06:12 AM
Those are the ones^^^^^ These are very nice and the best design I have found.
Old 06-20-2014, 11:26 AM
ragtopz28's Avatar
Ordered it...thanks. Part #RUS-644123
Old 06-24-2014, 06:59 AM
x275radial's Avatar
yeah I was just gonna say buy the ones that thread on. the plastics clips are no good.
Old 08-28-2014, 06:53 AM
Mike 02T/A's Avatar
How did the Russell fittings turn out? I'm about to order 2-3 of them, just curious. Can't beat it for under $15.
Old 08-28-2014, 09:29 AM
ragtopz28's Avatar
Worked like a charm
Quick Reply: Who make the best quick disconnect?
