ASR Off - In For Service
Well I'm waiting for the call to see what is going on with my car.
The "ASR Off" light has been on for years and I'm finally ready to pay somebody to look through the system. I've checked almost everything that I know to, so maybe the dealership can tell me some good news.
Fingers crossed...
I still have ABS, Cruise, and the car runs great. I'm really hoping for a frayed wire or bad wheel speed sensor. I'll report back for the record.
-JT
Fingers crossed...
-JT
Well after working on it off and on yesterday, they found out it has a C0238 fault code.
From what I have gathered over the years, the system always runs a test when you start the car. So the issue has basically been there for like 4 years.
I took it back in today and the plan is they are going to check wires/pins with an ohm meter and see what is what. No clue what they are going to find, I"m really hoping it is something stupid like a broken wire, speed sensor, or something like that.
Well apparently the EBCM is what the problem is.
The dealership says they can get it but the price is $1081... What I'm curious about is this a 1998 Camaro only part, or will a 99-02 unit work as well.
Also, is this just the black plastic part that is bolted to the big metal brake line junction near the front driver side of the engine? Just trying to get an idea what to look for and what to change out. I really think I can mess with this for less than $1k and figure it out with used parts or something else. From what I can gather these are not serviceable and just need replaced.
It is 1998 specific.
Do not replace the bcm as it is not the primary fault in the system. The bcm being fault would mean your car would not start and keyless entry wouldn't work
I would check your sensors on the rear end and replace any corroded ones.
The only 1998 vehicle I would pay $1k to fix an arbitrary traction control system on would be a 1998 ws6 formula 1le and they didn't even come with them. To pay 1k for something you turn off seems rediculous
The black canister next to the big silver one is the TCS asr module. If the system or bcm was faulty your cruise control would not work. On the 98 cars there are two throttle cables and the one coming out of the box is for cruise control
So if your cruise works there is a fault in the computer measuring the rear wheel speed to apply brakes for the traction control
The big black think you are referencing is the abs block for your brakes. The TCS asr module is a black canister behind the battery. None of my 1998 cars ever had traction control I believe they only came on Ss cars
Thanks for the insight. Not to worry, I'm not spending $1k on this, I agree on not needing it, turning it off all the time, etc.
The dealership gave me the printout of the procedure they followed and it was fairly lengthy. Came down to a fault in the EBCM, which from what I found is a Bosch 5.3 model.
I found a few companys online that rebuild these and fix the manufacturing issues that occur due to heat and vibration. I'm going to try this route first, it is pretty cheap and the guy I found who does it is very knowledgeable. I'll report back his findings soon.. Thanks again for the info!
haha - thanks.
The switch is spring loaded, not really an on/off type switch like the fog lights are. Just fyi..
I didn't post here for advice this time, I did in the past and found nobody really had a solution. I have seen other posts though where people had the same light on their dashboard, so I figured I'd offer what I have gone through just in case they need the assistance like I did in the past.
Technically not really doing what the dealer wants anyways. They are wanting to replace the module with a new GM unit for $1,000, charge $189 for labor and another $89 for a brake bleed. I am going to send mine away to one of the many websites that repairs the units for around $99. The dealership was basically used to diagnose the problem so now hopefully I should be able to remedy the issue on my own.
If you are somebody though who would like the unit replaced and not just repaired, Amazon has it for much cheaper than dealership list price, like most of their AC Delco parts. Here is the link for anybody else:
