No pcv valve... Wtf
No pcv valve... Wtf
Alright so basically I was going to replace my pcv valve and at first I looked around the valve covers and realized it's not like the old sbc style's... So after re-searching for the last hr I went and looked for it which it should be along the line that connects to TB and has foam over it. Well it's not there so I just want to check if this idling surging I have is because the pcv missing... Basically while idling the car has a slight surge then I take the oil cap off and boom it idles just fine so that'd make me think my pcv valve is shut but not missing correct???
Just wondering if somehow I missed the pcv valve
EDIT: Oh and I also disconnected the pcv line about halfway and I can blow/suck straight threw it so that should mean the pcv valve isn't there and I didn't overlook it huh?
Yes a picture would help. If its missing, yes I would install one. The lines are notorious for rotting so the previous owner may have replaced some/all of them and deleted the PVC while he was at it.
Is it routed like in the photo...?
http://ls1howto.com/howto/geniii/ls6...kpcvsystem.jpg
IMO, Google "LS1 PCV routing" , it should help give you a better visual reference .
It even has the hose that's labeled vent hose routed to TB like in pic.
Thanks for the help guys.
