Bad fuel pump?
Old 06-16-2014, 05:44 PM
Goodkat's Avatar
Default Bad fuel pump?
Im looking to buy a 01 SS but the owner says it has a bad fuel pump so theres no way for me to hear it running any ideas on how to tell if its in running condition without being able to start it?
Old 06-17-2014, 06:30 AM
Old Geezer's Avatar
yep.. Look at the car AFTER the seller fixes it.
BTW, wrong forum.
Old 06-17-2014, 03:09 PM
Goodkat's Avatar
BTW, wrong forum.
Such a helpful answer not arrogant at all.
FYI, sarcasm
Old 06-17-2014, 03:15 PM
01ssreda4's Avatar
He is trying to save your pocketbook. Every seller promises the world and most are lying through their teeth. Trust no one. A walbro pump is about $100-150. Mechanic shouldn't charge but a couple hundred to install it if the owner is incapable. If he is selling you a non-running car then the price better reflect that. If he is trying to get a couple hundred under full price then he is looking for a naive buyer.
Old 06-17-2014, 03:26 PM
Goodkat's Avatar
Hes asking 2000$ I can probably pick it up for 1500$ hes a friend of a friend getting divorced.
Old 06-17-2014, 03:48 PM
RockinWs6's Avatar
You asked............
Old 06-18-2014, 01:08 AM
Burken01's Avatar
2k for a car?
What else besides the pump is broken on it?
Old 06-18-2014, 06:54 AM
Old Geezer's Avatar
Default Good luck...
FYI, sarcasm
It's obvious you can't read, well. The forum is internal engine.. [Unless the fuel pump is now in the oil pan, that is.]
And as for taking someones "word", when spending considerable $$, then I refer to my title comment, "good luck".
Old 06-18-2014, 08:47 AM
Super Hulk Smash
JakeFusion's Avatar
Moving to fuel related forum.
Caveat Emptor!
On TBI/carb cars you could spray some fuel or starter fluid into the plenum and fire without a fuel pump. I don't know if I would try that with a LS1 style intake.
And for $1500-2000 it sounds like there are a lot of other problems. If you're buying it for a project car where you're doing to do a lot of work anyway... then yes. It would be fine as long as the body is straight and in good shape.
Quick Reply: Bad fuel pump?
