1994 Camaro Z28 6spd/ttop/375/390whp/t
Year: 1994
Make: Chevrolet
Model: Camaro
Price: $9500
Mileage: 156000
Private or Dealer Listing: Private Listing
Location (State): NY
Color: Blue
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
Motor/Clutch/-- Around 3000miles on them
Performance work to the car. List as follows:
Car dynoed tuned at 373hp/389Rwhp--(have dyno sheet) Car ran a best of 12.4x w/ 1.74 60' shifting at 5800-6000 Car Has High 11's in it
Engine-
- Decked/Balanced Rotating Assy/Line Honed/New Freeze Out Plugs/Polished and turned stock crank
-4bolt main block .30 over/ mahle forged pistons/eagle h-beam 6" rods/ file fit rings/all arp harware/ high volume oil pump
-Heads mild port work with bigger valve 2.0 1.56/3 angle valve job /54cc Heads/w/ comp 987 double springs
-CC503 Cam 537/544 lift
-Comp 7/16" Ultra Pro Mag 1.6rr (pic of engine shows old SA rockers)
-Trickflow Guide Plates
-arp 7/16" screw in studs
-Canton Fabbed Valve Covers
-Double Roller Timing Chain
-Electric Water Pump
-Moroso CAI
-Trickflow Ceramic Intake Arm
-Borla stainless CME(center mount exhaust) with painted valance
-Pacesetter offroad longtube headers/y-pipe
-BBK twin 58mm tb
-Ported Intake
-30# Redtop Svo injectors
-New GM Opti/Msd Plugs/NGK TR55 Plugs/All New Engine Sensors As Well
Suspension-
-Moser 12bolt with 4:11 gears
-Viking Double adjustable front coilovers w 300# race springs and 18 pos adjustable comp & rebound
-Viking Double adjustable rear shocks w 18 pos comp and rebound sitting on vogtland drop springs
-BMR adjustable torque arm
-BMR panhard bar
-BMR rlca's
-BMR tubular k-member(powdercoated hugger orange)
-BMR adjustable front lower control arms
-SPOHN fr. upper control arms
-Lakewood Driveshaft loop
-UMI 3 point Sfc's
-Brand New Fr Pads/Rotors
-Brand New R Pads/Rotors
-Fr Stainless brake lines
-New Rear Line W/ Adj Pro Valve
Transmission-
-6spd with spec stage 2+ clutch & pp
-stock lightened flywheel
-stock rims with m/t et streets >500 on them
Misc-
-Pioneer Deck W Aux output
-Subthump hidden box w/ pioneer 10" sub
-Sony Xplode 800 watt amp
-T-top Car
-SLP manual fan switch hi/low/stock operation function
-MSD Wires
-Autometer Level 2 Shift Light
-Scanmaster Lt1
-Walbro 255lph Fuel Pump
-SLP Custom Fit Cover
Also has a harwood 2.5" cowl hood
Comes with stock hood as well
ASKING 9500---Need the $ something big came up---Im sure its high for forums but i am def neg on price Any questions thanks
