F-body front upper control arm seal?
Old 06-18-2014, 05:53 PM
JimMueller's Avatar
Default F-body front upper control arm seal?
The rubber seal/bushing/gasket thing located where the spindle connects to the UCA with three bolts, is it individually replaceable? Mine are shredded but I cannot find a replacement for it.
Old 06-18-2014, 07:13 PM
Daniel Richards's Avatar
are you referring to the upper ball joint boot? If so the boot comes as part of the replacement ball joint, I've not seen sold separately in that location.
Old 06-18-2014, 07:46 PM
JimMueller's Avatar
Ah, yes, that's the correct term. Do you know if the Moog K6462 boot has a better design than OEM? I have Global West upper control arms and the mounting bolts seem to tear the seals up due to their close proximity to the boot.
Old 06-18-2014, 09:44 PM
are the bolts pointed up (so only the head of the bolt is on the boot side)?
add a picture so I can see the issue please.
Quick Reply: F-body front upper control arm seal?
