fuel rail
fuel rail
Hi Guys I am have an issue installing new injectors in my 2003 Z06 vette engine Every time I try to install the new injectors they leak fuel after the engine has being running for about 10 minutes. Can any one advise me on this Cheers
Are the "O" rings the correct size, the injectors the correct length.
Are the "O" rings getting nicked when they are installed?
Pre-lube them with a drop of engine oil or a spritz of WD-40 or petrolatum.
I have even used Chap Stick in a pinch.
