TU1.5 in a 5.3
TU1.5 in a 5.3
So here is the run down, keep in mind that this is not a street car
Thirdgen camaro 3500lbs
Junkyard 5.3
Head studs
Pac 1218
706 non castech heads
Ebay GT45 68mm
Meth Injection
Built TH400
3500 Stall
9" rear 3:50 gears
28" drag radial
What are your thoughts on the tu1.5 and the 5.3?
I picked the cam up local dirt cheap but I am wondering if I would have been better off with stock cam.
Junkyard 5.3
Head studs
Pac 1218
Ebay GT45 68mm
Meth Injection
Built TH400
3500 Stall
9" rear 3:50 gears
28" drag radial
Thanks for the reply. I have the cam in the car and it did not perform to expectation, I am sure I have more tuning to do. I just wanted to make sure I wasn't chasing my tail.
The car is just a nasty pig from dig, 1.8 has been my best 60ft time and I picked up no time on the big end. Like I said I still need to work on the tune but I thought I would pick up a couple MPH with cam only with a rough start on the tune. FYI I could not finish the tune at the track due to throwing a belt.
Thinking of ditching the GT45 and replacing with the new ON3 78/76 how would this cam work with the new turbo? You can PM if you like. Would I gain that much from a custom spec cam?
