Corvette 1/4" Thick Aluminum Ceramic Coated Tunnel Plate WITH Thermal-Abs
new in the box
http://www.ebay.com/itm/Corvette-1-4-Thick-Aluminum-Ceramic-Coated-Tunnel-Plate-WITH-Thermal-Abs-/231261891141?pt=Motors_Car_Truck_Parts_Accessories&hash=item35d8486a45&vxp=mtr
Brand New, bought it but never put it on. still new in the box.
1/4" Aluminum Tunnel Plate and "Thermal-Abs of Aluminum"
At a full 1/4" thick 6061-T6 aluminum, this plate is twice as thick as your stock OEM Tunnel Plate; Coated on all sides with a specially engineered ceramic coated and then bonded to a composite-fiberglass thermal barrier.
This is the best choice and BEST SELLER to offer both chassis stiffening and superior heat shielding to reduce the amount of heat transfer from the exhaust.
Since its release, the redesigned Tunnel Reinforcement Plate has been one of the hottest suspension mods for the C5 and C6 Corvette. Installed on both the C5R and C6R Race Corvettes, it has been proven over and over again to reduce the amount of torsional flex in the chassis. In addition, our ceramic coating adds another benefit by offering some heat shielding from your exhaust system.
The engineers at General Motors acknowledged the benefits of a stiffer more rigid Tunnel Reinforcement Plate and improved their original design and incorporated something similar into the new C6.
We have Taken their design one step further!
♦ Featured in both Corvette Fever and SPEED, STYLE, & SOUND magazine.
We have re-engineered the undercarriage tunnel plate on the C5 and C6 with strength and performance in mind. CAD designed and computer precision cut, our 1/4” thick (6061-T6 Aluminum) “Abs-of-Aluminum” Tunnel Reinforcement Plate is twice the thickness of the stock OEM plate. The benefits of this added thickness is a much more rigid and stiffer tunnel plate. Therefore reducing the amount of flex in the chassis and improving the overall functionality of the Corvette suspension.
Below is a picture comparing the stock OEM C5 and C6 tunnel plates to our most popular
1/4” thick aluminum version (Abs-of-Aluminum)
new in the box
