Boost 5.3 how much power to expect?
Old 06-20-2014, 05:18 PM
josh4ku's Avatar
Default Boost 5.3 how much power to expect?
I am working on a procharger build. Setup will be a 5.3L iron block 9.5:1 cr. Tick performance blower stage 1 v2 camshaft, Brian tooley springs, hardened pushrods, upgraded head gaskets not sure which yet, head studs, probably arp rod bolts, ls6 intake, d1sc procharger maybe 15lbs tuned on e85 , probably 90lb injectors with Lonnie's fuel system upgrade. How much hp can I expect from this setup ? Automatic trans (stock bottum end 5.3l)
Old 06-21-2014, 09:09 AM
josh4ku's Avatar
Bump.
Old 06-21-2014, 09:44 AM
mrstepheneades's Avatar
I would guess around high 600s thru auto. But im a turbo guy so really not sure. 16psi yielded 775 with my mid sized turbo t56 trans on my stock ls1. Lot of questions come up about the 5.3s. Guy on here just made 800 on 15psi thru twins 60somethings. Every setup yields such different numbers its hard to know unless you find someone who has your exact parts lol.
Old 06-21-2014, 11:03 AM
Blackpanther99's Avatar
600+ no doubt.
Old 06-21-2014, 01:10 PM
Heard somewhere on average it takes around 15 psi to double your engines n/a power output. From my experience with mine that's a pretty close figure.
Old 06-21-2014, 02:25 PM
josh4ku's Avatar
so what is the rwhp of a 5.3 and boost cam n/a approx?
Old 06-22-2014, 03:59 PM
With that compression I'd guess 330-340rwhp. May be way off.
Old 06-22-2014, 04:08 PM
LILHEMI's Avatar
more like 275-290.
Old 06-23-2014, 07:56 AM
Restricted User
JoeNova's Avatar
Originally Posted by LILHEMI
more like 275-290.
I dont think it would be quite that low. I helped with an L33 swap a couple of weeks ago and on stock cam with bolt ons he made 310whp. Through a 4L60e. A mild blower cam in a 5.3 should still give it a considerable power boost.
Old 06-23-2014, 10:06 AM
LILHEMI's Avatar
L33 is not an LM7 which is 99% of 5.3s out there.
Old 06-23-2014, 03:25 PM
Restricted User
JoeNova's Avatar
The only major advantages at stock L33 has over an LM7 is a very slightly larger cam and better heads. When you take the cam out of the equation you are just left with the heads, and a set of 799s and bolt-ons aren't going to outperform ANY of the other stock castings with a big cam.
Old 06-23-2014, 04:40 PM
LILHEMI's Avatar
why would you take the cam out of the equation when quoting stock horsepower figures?
Old 06-23-2014, 09:31 PM
DeboDaddy's Avatar
Probably because an LM7 with the L33 cam picks up 10hp at peak and 14hp at 6200rpm. Apples to apples buddy. That makes the difference between a stock LM7 and stock L33 a little less when using the same cam.
My guess would be 300-310rwhp through an auto, and probably 530-550rwhp at 15psi. More if it was a turbo car...
Old 06-23-2014, 10:22 PM
LILHEMI's Avatar
When did anybody EVER talk about an L33 cam in an lm7 in this thread???
Old 06-24-2014, 05:54 AM
Restricted User
JoeNova's Avatar
Because the LM7 he has doesn't have a stock cam. Besides the cam, the L33 has better heads and a tiny compression bump. You aren't comparing stock cams here. You're now comparing a stock L33 with a cammed LM7. The cammed LM7 is going to make more power.
Old 06-24-2014, 06:55 PM
DeboDaddy's Avatar
Hahaha I think you may be retarded. Are you completely unable to put 2 and 2 together?
Old 06-24-2014, 06:59 PM
LILHEMI's Avatar
no. thats 5.
Old 07-07-2014, 07:48 AM
josh4ku's Avatar
Why would the hp be more on a turbo car? Isnt 15lbs of boost the same no matter what the power adder is turbo , supercharger, procharger ?
Old 07-07-2014, 11:13 AM
LILHEMI's Avatar
boost is a measure of restriction......
Old 07-07-2014, 05:10 PM
josh4ku's Avatar
I thought boost was pounds of pressure the supercharger or turbo is creating..
Quick Reply: Boost 5.3 how much power to expect?
